Salta al contenuto principale
LG VX4500 screen replacement (duplicate)
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. LG VX4500 screen replacement (duplicate), Speaker: passo 1, immagine 1 di 2 LG VX4500 screen replacement (duplicate), Speaker: passo 1, immagine 2 di 2
    • Remove grey rubber caps from the four corners of the internal screen.
    • Remove the four 1.3 mm screws, which are directly underneath the grey caps, with a Phillips head screwdriver.
  2. LG VX4500 screen replacement (duplicate): passo 2, immagine 1 di 3 LG VX4500 screen replacement (duplicate): passo 2, immagine 2 di 3 LG VX4500 screen replacement (duplicate): passo 2, immagine 3 di 3
    • Run a pry bar along the seem of the edge of the phone to separate the top screen casing.
    • Work the bar around the edge until the entire top section with the LG logo is removed.
  3. LG VX4500 screen replacement (duplicate): passo 3, immagine 1 di 3 LG VX4500 screen replacement (duplicate): passo 3, immagine 2 di 3 LG VX4500 screen replacement (duplicate): passo 3, immagine 3 di 3
    • With a flathead screwdriver, lift the speaker from the device.
  4. LG VX4500 screen replacement (duplicate), Internal and External Screen: passo 4, immagine 1 di 3 LG VX4500 screen replacement (duplicate), Internal and External Screen: passo 4, immagine 2 di 3 LG VX4500 screen replacement (duplicate), Internal and External Screen: passo 4, immagine 3 di 3
    • Ensure that the metal capacitor next to the speaker is removed in the same way that the speaker was removed.
    • Gently lift the entire circuit board assembly up.
    • Note: the entire assembly is still connected to the phone.
  5. LG VX4500 screen replacement (duplicate): passo 5, immagine 1 di 2 LG VX4500 screen replacement (duplicate): passo 5, immagine 2 di 2
    • Desolder the contact point shown.
    • Gently pry the entire gold connector away from the screen with a spudger
Conclusione
iDeleted
Membro da: 07/07/10
2.101 Reputazione
39 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 198
