Salta al contenuto principale
LG VX4500 Rear Cover Replacement
Cosa ti serve
  1. LG VX4500 Rear Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. LG VX4500 Rear Cover Replacement: passo 2, immagine 1 di 2 LG VX4500 Rear Cover Replacement: passo 2, immagine 2 di 2
    • Now just lift up on the battery and remove it from the phone.
  3. LG VX4500 Rear Cover Replacement, Rear Cover: passo 3, immagine 1 di 1
    • Remove the rubber grommet using a Spudger.
  4. LG VX4500 Rear Cover Replacement: passo 4, immagine 1 di 1
    • Be sure not to lose the screws. They are small!
    • Remove the five screws using a Phillips #00 Screwdriver.
  5. LG VX4500 Rear Cover Replacement: passo 5, immagine 1 di 3 LG VX4500 Rear Cover Replacement: passo 5, immagine 2 di 3 LG VX4500 Rear Cover Replacement: passo 5, immagine 3 di 3
    • When removing back cover, be careful not to break the speaker wires.
    • Using an Opening Tool, carefully pry off the back cover.
    • Using tweezers, gently pull the speaker wires out.
  6. LG VX4500 Rear Cover Replacement: passo 6, immagine 1 di 1
    • Separate the two halves.
Conclusione
Cal Poly, Team 25-88, Amido Spring 2010 Membro di Cal Poly, Team 25-88, Amido Spring 2010
CPSU-AMIDO-S10S25G88
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,446
