Salta al contenuto principale
LG V30 Plus Rear Glass Replacement
Cosa ti serve
  1. LG V30 Plus Rear Glass Replacement, Rear Glass: passo 1, immagine 1 di 1
    • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
    • Allow to sit for 1-2 minutes to heat up the adhesive.
    • A heat gun may need to be used if you have trouble separating the backing in the next step.
  2. LG V30 Plus Rear Glass Replacement: passo 2, immagine 1 di 2 LG V30 Plus Rear Glass Replacement: passo 2, immagine 2 di 2
    • Insert an Opening Tool into the seam between the rear glass and side of the phone.
    • Pry the glass off just enough to insert an Opening Pick.
    • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
  3. LG V30 Plus Rear Glass Replacement: passo 3, immagine 1 di 1
    • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
Conclusione
Cal Poly, Team S1-G3, Maness Spring 2019 Membro di Cal Poly, Team S1-G3, Maness Spring 2019
CPSU-MANESS-S19S1G3
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,031
