Salta al contenuto principale
LG V30 Plus Battery Replacement
Cosa ti serve
  1. LG V30 Plus Battery Replacement, Rear Glass: passo 1, immagine 1 di 1
    • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
    • Allow to sit for 1-2 minutes to heat up the adhesive.
    • A heat gun may need to be used if you have trouble separating the backing in the next step.
  2. LG V30 Plus Battery Replacement: passo 2, immagine 1 di 2 LG V30 Plus Battery Replacement: passo 2, immagine 2 di 2
    • Insert an Opening Tool into the seam between the rear glass and side of the phone.
    • Pry the glass off just enough to insert an Opening Pick.
    • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
  3. LG V30 Plus Battery Replacement: passo 3, immagine 1 di 1
    • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
  4. LG V30 Plus Battery Replacement, Motherboard: passo 4, immagine 1 di 2 LG V30 Plus Battery Replacement, Motherboard: passo 4, immagine 2 di 2
    • Remove the ten 4mm screws using the Phillips #00 Screwdriver.
  5. LG V30 Plus Battery Replacement: passo 5, immagine 1 di 3 LG V30 Plus Battery Replacement: passo 5, immagine 2 di 3 LG V30 Plus Battery Replacement: passo 5, immagine 3 di 3
    • Gently push down on the small black tab with a Spudger to release the protective board.
    • Slide an Opening Tool between the phone and the protective board and slide along the edges of the phone to unclip it.
    • Carefully wiggle the board back and forth while gently pulling to unclip the last attachment point.
  6. LG V30 Plus Battery Replacement: passo 6, immagine 1 di 2 LG V30 Plus Battery Replacement: passo 6, immagine 2 di 2
    • Slide an Opening Tool between the lower protective board and the phone to unclip.
    • Slide the tool along the remaining edges of the protective board until it pops off.
  7. LG V30 Plus Battery Replacement: passo 7, immagine 1 di 2 LG V30 Plus Battery Replacement: passo 7, immagine 2 di 2
    • Gently pry each visible ribbon cable away from the motherboard to disconnect them.
  8. LG V30 Plus Battery Replacement: passo 8, immagine 1 di 1
    • Gently remove the motherboard from the phone.
  9. LG V30 Plus Battery Replacement, Battery: passo 9, immagine 1 di 3 LG V30 Plus Battery Replacement, Battery: passo 9, immagine 2 di 3 LG V30 Plus Battery Replacement, Battery: passo 9, immagine 3 di 3
    • Use a Spudger to get between the battery and the phone and pry each edge of the battery away from the board.
    • There may be a strong adhesive under the battery, so work your way around the battery carefully and slowly.
    • Insert Opening Picks if needed to keep the battery elevated.
Conclusione
Samuel Jahnke
Membro da: 04/22/19
282 Reputazione
2 Guide realizzate
Cal Poly, Team S1-G3, Maness Spring 2019 Membro di Cal Poly, Team S1-G3, Maness Spring 2019
CPSU-MANESS-S19S1G3
4 Membri
10 Guide realizzate
1Commento della guida
I did this and now my phone’s touch screen is unresponsive. The power button and volume buttons work and the phone turns on, but I cannot unlock my phone due to the touch screen not responding
Julian Marley - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 2,225
