Salta al contenuto principale
LG V20 Volume Button Replacement
Cosa ti serve
  1. LG V20 Volume Button Replacement, Battery: passo 1, immagine 1 di 3 LG V20 Volume Button Replacement, Battery: passo 1, immagine 2 di 3 LG V20 Volume Button Replacement, Battery: passo 1, immagine 3 di 3
    • Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
    • Be careful not to deform or puncture the battery.
    • Pry up and remove the battery.
  2. LG V20 Volume Button Replacement, Midframe Assembly: passo 2, immagine 1 di 1
    • Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
  3. LG V20 Volume Button Replacement: passo 3, immagine 1 di 2 LG V20 Volume Button Replacement: passo 3, immagine 2 di 2
    • The top and bottom frame section hold very tight to the mid frame. It is possible to pull them off with your hands. If you're not able to do so, use the following removal procedure:
    • Use the flat end of a spudger and apply pressure to one of the corners of the frame section until you create a small gap.
  4. LG V20 Volume Button Replacement: passo 4, immagine 1 di 2 LG V20 Volume Button Replacement: passo 4, immagine 2 di 2
    • Flip the phone and insert an opening pick in the gap you created.
    • Slide the opening pick along the gap until the frame section pops out of its plastic clamps.
  5. LG V20 Volume Button Replacement: passo 5, immagine 1 di 1
    • Remove the frame section.
    • Repeat this procedure with the frame section on the other end of the phone.
    • Within the top frame section there's a small silver grating that covers the speaker. This may fall out, so be careful not to lose it.
  6. LG V20 Volume Button Replacement: passo 6, immagine 1 di 2 LG V20 Volume Button Replacement: passo 6, immagine 2 di 2
    • The loudspeaker is attached to the cover of the motherboard. Use an opening pick to pry it up.
  7. LG V20 Volume Button Replacement: passo 7, immagine 1 di 2 LG V20 Volume Button Replacement: passo 7, immagine 2 di 2
    • The cover of the motherboard is held in its place by several plastic clamps.
    • Use an opening pick to pry up the motherboard cover at the right corner at the bottom of your phone until it pops out of the plastic clamp.
  8. LG V20 Volume Button Replacement: passo 8, immagine 1 di 2 LG V20 Volume Button Replacement: passo 8, immagine 2 di 2
    • Slide the opening pick along the mid frame and flip it sideways to open the plastic clamps holding the motherboard cover in its place.
  9. LG V20 Volume Button Replacement: passo 9, immagine 1 di 1
    • Remove the motherboard cover.
  10. LG V20 Volume Button Replacement, Volume Button: passo 10, immagine 1 di 2 LG V20 Volume Button Replacement, Volume Button: passo 10, immagine 2 di 2
    • Use the flat end of a spudger to slide the volume button out of its bracket and remove it.
Conclusione
Altre 7 persone hanno completato questa guida.
Cal Poly, Team S22-G5, Livingston Spring 2017 Membro di Cal Poly, Team S22-G5, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G5
4 Membri
36 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 24
Tutti i Tempi: 3,050
