Salta al contenuto principale
LG Ultimate 2 Digitizer Replacement
Cosa ti serve
  1. LG Ultimate 2 Digitizer Replacement, Battery: passo 1, immagine 1 di 1
    • Wedge the plastic opening tool into the seam between the plastic backing and the rest of the phone.
  2. LG Ultimate 2 Digitizer Replacement: passo 2, immagine 1 di 1
    • Use your hand to pull the plastic cover completely off of the phone.
  3. LG Ultimate 2 Digitizer Replacement: passo 3, immagine 1 di 1
    • Insert the plastic opening tool into the wedge near the bottom of the battery.
    • Lift the battery out.
  4. LG Ultimate 2 Digitizer Replacement, Digitizer: passo 4, immagine 1 di 2 LG Ultimate 2 Digitizer Replacement, Digitizer: passo 4, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the 11 mid-frame screws.
  5. LG Ultimate 2 Digitizer Replacement: passo 5, immagine 1 di 2 LG Ultimate 2 Digitizer Replacement: passo 5, immagine 2 di 2
    • Insert the plastic opening tool to start wedging the phone apart.
    • Trace the plastic opening tool along the edge for the entire perimeter of the phone, pulling it apart as you go.
  6. LG Ultimate 2 Digitizer Replacement: passo 6, immagine 1 di 1
    • Use a plastic opening tool or fingernail to separate the zip connector.
    • The zip connector does not detach completely from the phone, but acts as a flap.
  7. LG Ultimate 2 Digitizer Replacement: passo 7, immagine 1 di 1
    • Insert the plastic opening tool between the screen and the base. This may be difficult because of the adhesive, but enough leverage should force an opening.
  8. LG Ultimate 2 Digitizer Replacement: passo 8, immagine 1 di 1
    • Continue moving the plastic opening tool along the edge of the screen, separating the pieces from the adhesive.
    • A hair dryer might be useful to help melt the adhesive.
  9. LG Ultimate 2 Digitizer Replacement: passo 9, immagine 1 di 1
    • Pry the screen off after all pieces have been loosened from the adhesive.
Conclusione
IUPUI, Team S5-G2, Baechle Spring 2018 Membro di IUPUI, Team S5-G2, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G2
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 382
