Salta al contenuto principale
LG Tribute lower media Speaker Replacement
Cosa ti serve
  1. LG Tribute lower media Speaker  Replacement, Battery: passo 1, immagine 1 di 2 LG Tribute lower media Speaker  Replacement, Battery: passo 1, immagine 2 di 2
    • Use the plastic opening tool to pry off the back cover.
  2. LG Tribute lower media Speaker  Replacement: passo 2, immagine 1 di 1
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
  3. LG Tribute lower media Speaker  Replacement, Mid-panel: passo 3, immagine 1 di 2 LG Tribute lower media Speaker  Replacement, Mid-panel: passo 3, immagine 2 di 2
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
  4. LG Tribute lower media Speaker  Replacement: passo 4, immagine 1 di 2 LG Tribute lower media Speaker  Replacement: passo 4, immagine 2 di 2
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
  5. LG Tribute lower media Speaker  Replacement, Main media Speaker: passo 5, immagine 1 di 2 LG Tribute lower media Speaker  Replacement, Main media Speaker: passo 5, immagine 2 di 2
    • Use a plastic opening tool or your finger to carefully disconnect the speaker.
Conclusione
Altre 4 persone hanno completato questa guida.
3 Commenti
That's cool how did you get this stuff planned it is awsome.
Taziah brown - Replica
This is a brand new phone. Now I have to repair it? Something VERY WRONG with this picture! Is that the best sprint can do?
Ron Lieser - Replica
Brand new out of the box phone and I have to repair the speaker. I don't think so!
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 6
Tutti i Tempi: 947
