Introduzione
This guide will teach you how to properly replace the headphones jack in the LG Tribute HD LS676.
Parti
Nessuna parte richiesta.
  1. Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
    • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
  2. Pull the battery out of the phone.
    • Pull the battery out of the phone.
    • Remove the SD Card by sliding the card out as shown.
    • Remove the twelve 2mm JIS #00 screws from the mid-frame.
    • Using a plastic opening tool, remove the antenna extender from the mid-frame.
    • Using your fingers, remove the mid-frame.
    • Use plastic opening tool to pry up the flex cable from the back panel.
    • Flip over and push on the back side of the headphone jack to dislodge it.
Conclusione
Jerry Koenig
Membro da: 14/02/2018
587 Reputazione
4 Guide realizzate
USF Tampa, Team S1-G3, Nance Spring 2018 Membro di USF Tampa, Team S1-G3, Nance Spring 2018
USFT-NANCE-S18S1G3
4 Membri
10 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 186
