Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
This guide will walk you through replacing your LG Tribute 5’s front speaker. If your audio is distorted or not working on the front of the phone, replacing the front speaker may fix this issue.
Parti
Nessuna parte specificata.
  1. Using an iFixit opening tool, gently pull outward on the cutout on the bottom left corner of the phone to remove the back cover. Using an iFixit opening tool, gently pull outward on the cutout on the bottom left corner of the phone to remove the back cover.
    • Using an iFixit opening tool, gently pull outward on the cutout on the bottom left corner of the phone to remove the back cover.
  2. Gently lift the battery out from the compartment. Use an iFixit opening tool to slide out the SD card and nano sim card from the device as shown. Use an iFixit opening tool to slide out the SD card and nano sim card from the device as shown.
    • Gently lift the battery out from the compartment.
    • Use an iFixit opening tool to slide out the SD card and nano sim card from the device as shown.
  3. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Remove the nine 2mm JIS #00 screws from the mid-frame. Remove the nine 2mm JIS #00 screws from the mid-frame. Remove the nine 2mm JIS #00 screws from the mid-frame.
    • Remove the nine 2mm JIS #00 screws from the mid-frame.
  5. Using an iFixit opening tool, remove the antenna extender located at the bottom. Using an iFixit opening tool, remove the antenna extender located at the bottom. Using an iFixit opening tool, remove the antenna extender located at the bottom.
    • Using an iFixit opening tool, remove the antenna extender located at the bottom.
  6. Gently remove the mid-frame using an iFixit opening tool. Avoid applying too much force when separating the mid frame. Too much force can bend or damage the device.
    • Gently remove the mid-frame using an iFixit opening tool.
    • Avoid applying too much force when separating the mid frame. Too much force can bend or damage the device.
  7. Using an iFixit opening tool, gently pull up the front speaker from its compartment located on the top of the motherboard.
    • Using an iFixit opening tool, gently pull up the front speaker from its compartment located on the top of the motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 73
