Salta al contenuto principale
LG Tribute 5 Motherboard Replacement
Cosa ti serve
  1. LG Tribute 5 Motherboard Replacement, Battery: passo 1, immagine 1 di 2 LG Tribute 5 Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • Using an iFixit opening tool, gently pull outward on the cutout on the bottom left corner of the phone to remove the back cover.
  2. LG Tribute 5 Motherboard Replacement: passo 2, immagine 1 di 3 LG Tribute 5 Motherboard Replacement: passo 2, immagine 2 di 3 LG Tribute 5 Motherboard Replacement: passo 2, immagine 3 di 3
    • Gently lift the battery out from the compartment.
    • Use an iFixit opening tool to slide out the SD card and nano sim card from the device as shown.
  3. LG Tribute 5 Motherboard Replacement, Motherboard: passo 3, immagine 1 di 3 LG Tribute 5 Motherboard Replacement, Motherboard: passo 3, immagine 2 di 3 LG Tribute 5 Motherboard Replacement, Motherboard: passo 3, immagine 3 di 3
    • Remove the nine 2mm JIS #00 screws from the mid-frame.
  4. LG Tribute 5 Motherboard Replacement: passo 4, immagine 1 di 3 LG Tribute 5 Motherboard Replacement: passo 4, immagine 2 di 3 LG Tribute 5 Motherboard Replacement: passo 4, immagine 3 di 3
    • Using an iFixit opening tool, remove the antenna extender located at the bottom.
  5. LG Tribute 5 Motherboard Replacement: passo 5, immagine 1 di 2 LG Tribute 5 Motherboard Replacement: passo 5, immagine 2 di 2
    • Gently remove the mid-frame using an iFixit opening tool as shown.
    • Avoid applying too much force when separating the mid frame. Too much force can bend or damage the device.
  6. LG Tribute 5 Motherboard Replacement: passo 6, immagine 1 di 2 LG Tribute 5 Motherboard Replacement: passo 6, immagine 2 di 2
    • Using an iFixit opening tool, gently disconnect the rear camera from the top center of the motherboard.
    • Remove the front facing camera from the top right corner of the motherboard.
  7. LG Tribute 5 Motherboard Replacement: passo 7, immagine 1 di 1
    • Gently pull the speaker out from its compartment with the iFixit opening tool.
  8. LG Tribute 5 Motherboard Replacement: passo 8, immagine 1 di 1
    • Disconnect the flex cable from the motherboard with the iFixit opening tool.
  9. LG Tribute 5 Motherboard Replacement: passo 9, immagine 1 di 1
    • Gently pull up and remove the motherboard using the iFixit opening tool.
Conclusione
Altre 4 persone hanno completato questa guida.
UW Tacoma, Team S1-G6, Cardinal Spring 2019 Membro di UW Tacoma, Team S1-G6, Cardinal Spring 2019
UWT-CARDINAL-S19S1G6
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 384
