Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide will show you how to replace the headphone jack in your LG Tribute 5, model LS675. When you insert your headphones into your device and are unable to hear anything or you audio is distorted, replacing the headphone jack may fix this issue.
Parti
Nessuna parte specificata.
  1. Using an iFixit opening tool, gently pull outward on the cutout on the bottom left corner of the phone to remove the back cover. Using an iFixit opening tool, gently pull outward on the cutout on the bottom left corner of the phone to remove the back cover.
    • Using an iFixit opening tool, gently pull outward on the cutout on the bottom left corner of the phone to remove the back cover.
  2. Gently lift the battery out from the compartment. Use an iFixit opening tool to slide out the SD card and nano sim card from the device as shown. Use an iFixit opening tool to slide out the SD card and nano sim card from the device as shown.
    • Gently lift the battery out from the compartment.
    • Use an iFixit opening tool to slide out the SD card and nano sim card from the device as shown.
  3. Remove the nine 2mm JIS #00 screws from the mid-frame. Remove the nine 2mm JIS #00 screws from the mid-frame. Remove the nine 2mm JIS #00 screws from the mid-frame.
    • Remove the nine 2mm JIS #00 screws from the mid-frame.
  4. Using an iFixit opening tool, remove the antenna extender located at the bottom. Using an iFixit opening tool, remove the antenna extender located at the bottom. Using an iFixit opening tool, remove the antenna extender located at the bottom.
    • Using an iFixit opening tool, remove the antenna extender located at the bottom.
  5. Gently remove the mid-frame using an iFixit opening tool as shown. Avoid applying too much force when separating the mid frame. Too much force can bend or damage the device.
    • Gently remove the mid-frame using an iFixit opening tool as shown.
    • Avoid applying too much force when separating the mid frame. Too much force can bend or damage the device.
  6. Use an iFixit opening tool to remove the headphone jack.
    • Use an iFixit opening tool to remove the headphone jack.
Conclusione
Kevin Hernon
Membro da: 22/04/2019
295 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 129
