Introduzione
This guide will replace the loudspeaker which is located on the back of the phone digitizer.
Cosa ti serve
Pull off the back cover from the phone using the groove on the bottom right side.
Remove all 9 of the 3mm Phillips #000 screws from the digitizer.
Remove the digitizer like you did the back cover by working your way around the edge peeling it up.
Conclusione
