Salta al contenuto principale
LG Treasure Auxiliary Port Replacement
Cosa ti serve
  1. LG Treasure Auxiliary Port Replacement, Battery: passo 1, immagine 1 di 2 LG Treasure Auxiliary Port Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure the LG Treasure is turned off.
    • Pull off the back cover from the phone using the groove on the bottom right side.
  2. LG Treasure Auxiliary Port Replacement: passo 2, immagine 1 di 1
    • Remove the battery from the phone by lifting up on the bottom end of the battery.
  3. LG Treasure Auxiliary Port Replacement, Auxiliary Port: passo 3, immagine 1 di 2 LG Treasure Auxiliary Port Replacement, Auxiliary Port: passo 3, immagine 2 di 2
    • Remove all 9 of the 3mm Phillips #000 screws from the digitizer.
    • Work your way around the edge of the phone, gently prying the digitizer off the phone.
  4. LG Treasure Auxiliary Port Replacement: passo 4, immagine 1 di 3 LG Treasure Auxiliary Port Replacement: passo 4, immagine 2 di 3 LG Treasure Auxiliary Port Replacement: passo 4, immagine 3 di 3
    • Insert your finger nail into the groove under the Auxiliary Port and pry the Auxiliary Port out.
Conclusione
UW Stout, Team S8-G5, Ogden Spring 2018 Membro di UW Stout, Team S8-G5, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G5
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 260
