Salta al contenuto principale
LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement
Cosa ti serve
  1. LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Remove hidden screw.: passo 1, immagine 1 di 3 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Remove hidden screw.: passo 1, immagine 2 di 3 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Remove hidden screw.: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • First, see which side speaker needs to be replaced.
    • Locate the hidden screw as shown in the picture and remove the rubber piece with tweezers.
    • Remove the screw using a Philips #00 screwdriver.
  2. LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Disassemble the headset.: passo 2, immagine 1 di 3 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Disassemble the headset.: passo 2, immagine 2 di 3 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Disassemble the headset.: passo 2, immagine 3 di 3
    • Using a guitar pick or any opening tool, open the frame of the headset.
  3. LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Remove motherboard screw.: passo 3, immagine 1 di 1
    • Using a Philips #00 screwdriver remove the screw holding the motherboard in place.
  4. LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Move speaker to uncover hidden screw.: passo 4, immagine 1 di 3 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Move speaker to uncover hidden screw.: passo 4, immagine 2 di 3 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Move speaker to uncover hidden screw.: passo 4, immagine 3 di 3
    • Slightly push back on the speaker back housing so the speaker can be pushed out as seen in the pictures.
  5. LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Remove speaker hidden screw.: passo 5, immagine 1 di 2 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Remove speaker hidden screw.: passo 5, immagine 2 di 2
    • Once the speaker is out of the way, the hidden screw can be removed using a Philips #00 screwdriver.
  6. LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Remove speaker and motherboard.: passo 6, immagine 1 di 3 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Remove speaker and motherboard.: passo 6, immagine 2 di 3 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Remove speaker and motherboard.: passo 6, immagine 3 di 3
    • Using a pry/opening tool, slightly lift the speaker and motherboard out of place.
  7. LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Desolder the speaker.: passo 7, immagine 1 di 2 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Desolder the speaker.: passo 7, immagine 2 di 2
    • Use a soldering iron to desolder the speaker from the motherboard.
Conclusione
Altre 14 persone hanno completato questa guida.
Faizan Naveed
Membro da: 04/12/17
3.294 Reputazione
8 Guide realizzate
Mobile Device Repair Factory Membro di Mobile Device Repair Factory
Business
1 Membro
16 Guide realizzate
8 Commenti
Thanks for such a thorough guide! Would you happen to know where I could find replacement parts without buying whole units on ebay?
Jordan Heilman - Replica
Your welcome! Not sure where you can buy just replacement parts at the moment. Best bet would be to buy a unit for parts on ebay or amazon.
Faizan Naveed -
I can't hear noise from my left earbud of my lg tone ultra plz tell me how can i fix this problem.few months ago my headphone were working well but after they got in the hands of my nephew accidentally first the sound become disbalance like right earbud can be louder than left one,but after time passes the sound in the left earbud comes to zero and now there is no sound coming out of left earbud ….I can't buy new headphone i would like to repaire it ….!!!
Ali Anwar - Replica
Soak the earbuds in rubbing, isopropyl, or ethanol at 50-70% concentration for an hour. Let it dry out for an hour. The solution will remove salt and other residue from sweat, which causes one side to lose sound over time.
Tung Nguyen - Replica
Still no info on replacement parts?
rezinkillz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 35
Tutti i Tempi: 16,260
