Salta al contenuto principale
LG Tone Infinim HBS-910 Battery Replacement
Cosa ti serve
  1. LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: passo 1, immagine 1 di 3 LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: passo 1, immagine 2 di 3 LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: passo 1, immagine 3 di 3
    • Battery is on right side of headset.
    • First remove rubber cover on the right side of the headset to uncover the hidden screw.
    • Remove screw using Philips PH00 screwdriver.
  2. LG Tone Infinim HBS-910 Battery Replacement, Disassemble right side.: passo 2, immagine 1 di 2 LG Tone Infinim HBS-910 Battery Replacement, Disassemble right side.: passo 2, immagine 2 di 2
    • Use a guitar pick or any opening tool to pry open the right side.
  3. LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: passo 3, immagine 1 di 3 LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: passo 3, immagine 2 di 3 LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: passo 3, immagine 3 di 3
    • Once you have opened the right side up until the speaker end, there will be a hidden screw that needs to be unscrewed before the right side can be completely disassembled.
    • Pry open the speaker back housing with a guitar pick or any opening tool as shown in the picture.
    • Once the speaker back housing is lifted, you will see the screw.
    • Remove the screw and the whole right side will be disassembled.
  4. LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: passo 4, immagine 1 di 3 LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: passo 4, immagine 2 di 3 LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: passo 4, immagine 3 di 3
    • Use a non-metal tool to lift the battery out of place so it will be easy to desolder.
    • Remember the red wire is positive(+) and the black wire is negative(-).
Conclusione
Altre 13 persone hanno completato questa guida.
Faizan Naveed
Membro da: 04/12/17
3.294 Reputazione
8 Guide realizzate
Mobile Device Repair Factory Membro di Mobile Device Repair Factory
Business
1 Membro
16 Guide realizzate
2 Commenti
Battery model and amps
honda kung - Replica
Hello budy!
Tanks for the guide, i was going crazy looking for that hidden screw!
You might be able to help me. Would you know what i must look for a malfunctioning earbud? My right one suddenly died and im hoping the cord isn't broken and its just some loose weld.
Rafael Zerbini - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 29
Tutti i Tempi: 11,258
