Salta al contenuto principale
LG Sunrise Midframe Replacement
Cosa ti serve
  1. LG Sunrise Midframe Replacement, Back cover: passo 1, immagine 1 di 1
    • Flip the phone over so the back side is facing you.
  2. LG Sunrise Midframe Replacement: passo 2, immagine 1 di 1
    • Use a prying tool or a flat head screwdriver to pry the back cover from the device.
  3. LG Sunrise Midframe Replacement: passo 3, immagine 1 di 1
    • Set back panel aside for later use or to replace.
  4. LG Sunrise Midframe Replacement, Battery: passo 4, immagine 1 di 2 LG Sunrise Midframe Replacement, Battery: passo 4, immagine 2 di 2
    • Use your finger to pull out battery from the bottom of the device.
  5. Attenzione: i passaggi 5-6 provengono da una guida contrassegnata come in corso.
    LG Sunrise Midframe Replacement, Lower Back Plastic Piece: passo 5, immagine 1 di 3 LG Sunrise Midframe Replacement, Lower Back Plastic Piece: passo 5, immagine 2 di 3 LG Sunrise Midframe Replacement, Lower Back Plastic Piece: passo 5, immagine 3 di 3
    • You will be first removing the two lower screws. This is allow you to remove the lower plastic piece.
  6. LG Sunrise Midframe Replacement: passo 6, immagine 1 di 1
    • Once both of the screws are out you can easily pop off the bottom piece.
  7. LG Sunrise Midframe Replacement, Midframe: passo 7, immagine 1 di 2 LG Sunrise Midframe Replacement, Midframe: passo 7, immagine 2 di 2
    • Once you have removed all 6 screws. Gently pry all sides of back plastic piece, starting at the bottom. Once you start on the bottom, it will become easier to pry.
  8. LG Sunrise Midframe Replacement: passo 8, immagine 1 di 2 LG Sunrise Midframe Replacement: passo 8, immagine 2 di 2
    • Once you have pried off the back piece, the mother board should be exposed. Set this piece aside for replacement or reassembly.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 261
