Salta al contenuto principale
LG Stylo 3 Plus Front Camera Replacement
Cosa ti serve
  1. LG Stylo 3 Plus Front Camera Replacement, Back Cover: passo 1, immagine 1 di 3 LG Stylo 3 Plus Front Camera Replacement, Back Cover: passo 1, immagine 2 di 3 LG Stylo 3 Plus Front Camera Replacement, Back Cover: passo 1, immagine 3 di 3
    • Power off the phone before beginning disassembly.
    • Place the phone face down.
    • Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
    • Carefully slide your finger or the tool throughout the edge of the phone to ease the back case off.
  2. LG Stylo 3 Plus Front Camera Replacement, Battery: passo 2, immagine 1 di 3 LG Stylo 3 Plus Front Camera Replacement, Battery: passo 2, immagine 2 di 3 LG Stylo 3 Plus Front Camera Replacement, Battery: passo 2, immagine 3 di 3
    • Place the back cover off to the side.
    • Insert the opening tool into the small gap below the battery.
    • Carefully pop the battery out to prevent damage.
  3. LG Stylo 3 Plus Front Camera Replacement, Rear Camera: passo 3, immagine 1 di 3 LG Stylo 3 Plus Front Camera Replacement, Rear Camera: passo 3, immagine 2 di 3 LG Stylo 3 Plus Front Camera Replacement, Rear Camera: passo 3, immagine 3 di 3
    • Remove the twelve 4mm screws using the Phillips #000 screwdriver.
    • Use the plastic opening tool to remove the inner case.
    • Carefully remove the inner case.
  4. LG Stylo 3 Plus Front Camera Replacement: passo 4, immagine 1 di 2 LG Stylo 3 Plus Front Camera Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use your fingernail or the plastic opening tool to flip the flex cable.
    • Use the precision tweezers to carefully grasp and pull out the camera.
  5. LG Stylo 3 Plus Front Camera Replacement, Front Camera: passo 5, immagine 1 di 2 LG Stylo 3 Plus Front Camera Replacement, Front Camera: passo 5, immagine 2 di 2
    Compra
    • Carefully flip open the flex cable box with the plastic opening tool.
    • Using precision tweezers, carefully lift the front camera off the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 813
