Introduzione
For this removal you will need a PH00 screw driver to remove the necessary screws. It is recommended to have very clean hands or even to wear gloves as you will be interacting with the motherboard of the phone.
Cosa ti serve
First you need to remove the back case of the phone.
Place the phone face down.
Using the plastic opening tool, insert into the initial gap shown.
Slowly guide the tool around the case until the case comes off with ease.
Remove the eleven 4mm Phillips #00 screws.
Place screws in safe location.
Use Plastic opener tool to remove inner case.
Gently remove inner case.
