Introduzione
If your LG Stylo 2 Plus has a cracked screen or dead pixels, then the screen should be replaced. This will require a several tools and a heat gun. This is a relatively challenging task; be especially careful when removing ribbon cables.
Cosa ti serve
To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
Firmly grasp the battery and remove from the phone.
Using the JIS #000 screwdriver, remove the eleven 4mm screws around the mid-frame.
Briefly run the heat gun on a low setting around the outside edge of the screen to warm up the adhesive keeping the phone in place.
Keep heat gun on a low setting, and keep the point you are heating moving. Do not hold the heat gun in one spot for long.
Work an iFixit opening tool under the lip of the screen and pry upwards carefully.
Once you are able to work the screen up around the edge of the device, pull the ribbon cable out of the phone through the thin slot at the bottom of the phone.
To reassemble your device, apply the new screen to the phone frame, and follow these instructions in reverse order.
Altre 3 persone hanno completato questa guida.
Un commento
Good afternoon, I greet you from Guatemla, I need your help, could you provide me with the schematic diagram of the LG MS550 phone
