Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
If the audio still skips or doesn't work even after trying to use different headphones then you may need to replace the Audio Jack in the phone. This guide will take you through the necessary steps to accomplish this.
  1. Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone. Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
    • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
  2. Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
    • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
  3. Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver. Use the magnet board to keep the screws in one place.
    • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
    • Use the magnet board to keep the screws in one place.
  4. Use the plastic opening tool to firmly unhinge the plastic backing around the perimeter of the phone.
    • Use the plastic opening tool to firmly unhinge the plastic backing around the perimeter of the phone.
  5. Using the plastic opening tool, gently pry up the plastic film connecting the audio port to the motherboard. Using the plastic opening tool, gently pry up the plastic film connecting the audio port to the motherboard.
    • Using the plastic opening tool, gently pry up the plastic film connecting the audio port to the motherboard.
  6. Remove the audio port from the motherboard either with your hand or the plastic opening tool.
    • Remove the audio port from the motherboard either with your hand or the plastic opening tool.
Conclusione
Aiman Sallam
Membro da: 10/02/2016
506 Reputazione
5 Guide realizzate
USF Tampa, Team 1-4, Sullivan Spring 2016 Membro di USF Tampa, Team 1-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G4
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 129
