Cosa ti serve
Use a plastic opening tool to seperate the back panel from the device.
Remove the back panel.
Place your thumb along the bottom of the battery and pry upwards to remove.
Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
Unclip the front camera connector from the motherboard and lift it from the frame.
Detach the screen connector from the motherboard by putting your thumb underneath it and lifting up.
Using a hot air gun or hair dryer, heat the screen assembly, and pry it from the frame using your fingers (or an iFixit prying tool).
2 Commenti
Thank you John Breaux! Clear and precise instructions! Easy to follow! Like a US Army instruction manual. Big help fixing my homeless friend's phone! Now she can at least stay in touch and find better help! I thank you and little June says thank you and she will pray for your health and happiness.She is 208 days sober and grateful for every bit of help in her life.
You're welcome! Congratulations to your friend for 208 days sober! I wish you both good health and happiness as well.
