Salta al contenuto principale
LG Rebel Rear Camera Replacement
Cosa ti serve
  1. LG Rebel Rear Camera Replacement, Rear Camera: passo 1, immagine 1 di 2 LG Rebel Rear Camera Replacement, Rear Camera: passo 1, immagine 2 di 2
    • Turn the phone on its side and locate the small groove.
    • Use the plastic opening tool to take the back cover off of the phone.
  2. LG Rebel Rear Camera Replacement: passo 2, immagine 1 di 3 LG Rebel Rear Camera Replacement: passo 2, immagine 2 di 3 LG Rebel Rear Camera Replacement: passo 2, immagine 3 di 3
    • Locate the small groove on the back of the phone near the bottom.
    • Use the metal spudger to pop open the black plastic covering.
    • Remove black plastic covering.
  3. LG Rebel Rear Camera Replacement: passo 3, immagine 1 di 2 LG Rebel Rear Camera Replacement: passo 3, immagine 2 di 2
    • Use the metal spudger to pop up the black plastic covering near top of phone.
    • Remove the black plastic covering.
  4. LG Rebel Rear Camera Replacement: passo 4, immagine 1 di 3 LG Rebel Rear Camera Replacement: passo 4, immagine 2 di 3 LG Rebel Rear Camera Replacement: passo 4, immagine 3 di 3
    • Locate the connective pieces on the back of the phone.
    • Use the metal spudger to disconnect both of the connective pieces from the back.
  5. LG Rebel Rear Camera Replacement: passo 5, immagine 1 di 3 LG Rebel Rear Camera Replacement: passo 5, immagine 2 di 3 LG Rebel Rear Camera Replacement: passo 5, immagine 3 di 3
    • Flip the phone over so the screen is facing up.
    • Slide the metal spudger around the perimeter of the phone until the entire seal has been broken.
    • Use the small suction cup to remove the screen.
  6. LG Rebel Rear Camera Replacement: passo 6, immagine 1 di 2 LG Rebel Rear Camera Replacement: passo 6, immagine 2 di 2
    • Locate the black bumper at the bottom of the front of the phone.
    • Use the metal spudger to slide the bumper out.
  7. LG Rebel Rear Camera Replacement: passo 7, immagine 1 di 3 LG Rebel Rear Camera Replacement: passo 7, immagine 2 di 3 LG Rebel Rear Camera Replacement: passo 7, immagine 3 di 3
    • Use the metal spudger to carefully loosen the motherboard from the body of the phone.
    • Slowly slide the motherboard out of the body of the phone.
    • Remove the motherboard.
  8. LG Rebel Rear Camera Replacement: passo 8, immagine 1 di 2 LG Rebel Rear Camera Replacement: passo 8, immagine 2 di 2
    • Locate the rear camera on the motherboard.
    • Use the metal spudger to disconnect the connective piece at the base of the camera.
    • Remove the camera.
Conclusione
Emma Johnson
Membro da: 02/08/18
184 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 479
