Salta al contenuto principale
LG Rebel Front Camera Replacement
Cosa ti serve
  1. LG Rebel Front Camera Replacement, Front Camera: passo 1, immagine 1 di 3 LG Rebel Front Camera Replacement, Front Camera: passo 1, immagine 2 di 3 LG Rebel Front Camera Replacement, Front Camera: passo 1, immagine 3 di 3
    • Turn phone over to its front side.
    • Use a spudger to begin removing the screen by the right hand corner. Begin to move the tool around the edges of the screen.
  2. LG Rebel Front Camera Replacement: passo 2, immagine 1 di 3 LG Rebel Front Camera Replacement: passo 2, immagine 2 di 3 LG Rebel Front Camera Replacement: passo 2, immagine 3 di 3
    • Once you have loosened the grip around the edges, pop off the screen using a suction cup.
    • Once the front screen is removed, place the phone on its side and find the groove located on the side.
    • Use the plastic opening tool to pop open the black plastic covering.
    • Remove black plastic cover.
  3. LG Rebel Front Camera Replacement: passo 3, immagine 1 di 3 LG Rebel Front Camera Replacement: passo 3, immagine 2 di 3 LG Rebel Front Camera Replacement: passo 3, immagine 3 di 3
    • Locate the small groove on the back of the phone near the bottom.
    • Use the metal spudger to pop open the black plastic covering.
    • Remove black plastic covering.
  4. LG Rebel Front Camera Replacement: passo 4, immagine 1 di 2 LG Rebel Front Camera Replacement: passo 4, immagine 2 di 2
    • Use the metal spudger to pop up the black plastic covering near top of phone.
    • Remove the black plastic covering.
  5. LG Rebel Front Camera Replacement: passo 5, immagine 1 di 3 LG Rebel Front Camera Replacement: passo 5, immagine 2 di 3 LG Rebel Front Camera Replacement: passo 5, immagine 3 di 3
    • Remove the motherboard with a spudger.
    • Slowly begin to lift motherboard with your hand carefully.
    • Once the motherboard is completely off, set the phone to the side and focus on the small black box with a square tail (which is the front camera).
  6. LG Rebel Front Camera Replacement: passo 6, immagine 1 di 2 LG Rebel Front Camera Replacement: passo 6, immagine 2 di 2
    • Remove the front camera by its tail with a spudger.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 357
