Salta al contenuto principale
LG Realm Plastic Midframe Replacement
Cosa ti serve
  1. LG Realm Plastic Midframe Replacement, Battery: passo 1, immagine 1 di 2 LG Realm Plastic Midframe Replacement, Battery: passo 1, immagine 2 di 2
    • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
    • Use nail to loosen case on all four sides. Once loose, remove back case.
  2. LG Realm Plastic Midframe Replacement: passo 2, immagine 1 di 1
    • Insert thumbnail into tab below battery.
    • Pull away from phone and remove.
  3. LG Realm Plastic Midframe Replacement, Plastic Midframe: passo 3, immagine 1 di 2 LG Realm Plastic Midframe Replacement, Plastic Midframe: passo 3, immagine 2 di 2
    • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
  4. LG Realm Plastic Midframe Replacement: passo 4, immagine 1 di 1
    • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
Conclusione
Altre 5 persone hanno completato questa guida.
Marist, Team 1-5, Laflen Spring 2016 Membro di Marist, Team 1-5, Laflen Spring 2016
MARS-LAFLEN-S16S1G5
2 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 326
