Introduzione
Before continuing, make sure the device is powered down. Also make sure that the battery and back casing are removed.
Cosa ti serve
To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
Use nail to loosen case on all four sides. Once loose, remove back case.
Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
Locate the front facing camera in the top left hand corner of the motherboard. Using the plastic opening tool, separate the ribbon cable from the phone.
Altre 4 persone hanno completato questa guida.
