Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
If you need to install a new front camera on your LG Phoenix 2, use this guide to disassemble and replace the damaged front camera. For this guide you will need a plastic opening tool and a Phillips #000 screwdriver head. These steps will be straightforward and easy to follow, but the pieces should be handled with care, so as to not damage or misplace any needed components.
  1. Insert a fingernail into the notch on the bottom right corner of the phone. Remove the back cover off of the device.
    • Insert a fingernail into the notch on the bottom right corner of the phone.
    • Remove the back cover off of the device.
  2. Insert a fingernail into the notch under the battery.
    • Insert a fingernail into the notch under the battery.
    • Remove the battery.
  3. Insert the opening tool under the bottom cover. Pop off the bottom cover.
    • Insert the opening tool under the bottom cover.
    • Pop off the bottom cover.
  4. Remove eight 3mm screws using the Phillips #0 screwdriver.
    • Remove eight 3mm screws using the Phillips #0 screwdriver.
  5. Insert the opening tool in between the phone screen and the silver trim. Pop off the silver trim.
    • Insert the opening tool in between the phone screen and the silver trim.
    • Pop off the silver trim.
  6. Insert the opening tool under the bottom of the front camera connection to the motherboard. Pop off the front camera.
    • Insert the opening tool under the bottom of the front camera connection to the motherboard.
    • Pop off the front camera.
Conclusione
Sarah Popp
Membro da: 26/11/2018
395 Reputazione
3 Guide realizzate
IUPUI, Team S7-G7, Wilson Fall 2018 Membro di IUPUI, Team S7-G7, Wilson Fall 2018
IUPUI-WILSON-F18S7G7
4 Membri
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 88
