Salta al contenuto principale
LG Optimus T Motherboard Replacement
Cosa ti serve
  1. LG Optimus T Motherboard Replacement, Motherboard: passo 1, immagine 1 di 3 LG Optimus T Motherboard Replacement, Motherboard: passo 1, immagine 2 di 3 LG Optimus T Motherboard Replacement, Motherboard: passo 1, immagine 3 di 3
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Using a prying device, such as a plastic opening tool, remove the phone’s back cover. At the top of the phone, there’s an indentation to put the Spudger into to pop the case off
  2. LG Optimus T Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the battery. There’s an indentation to the left of the camera lens to pull up on the battery with your finger
  3. LG Optimus T Motherboard Replacement: passo 3, immagine 1 di 1
    • Use a J0 screwdriver to remove the six 4.5mm screws.
  4. LG Optimus T Motherboard Replacement: passo 4, immagine 1 di 2 LG Optimus T Motherboard Replacement: passo 4, immagine 2 di 2
    • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic opening tool fails
    • Remove interior case. Insert the spudger into the indentations at the top, or bottom of the phone to pry off the interior case.
  5. LG Optimus T Motherboard Replacement: passo 5, immagine 1 di 1
    • Pull up on connector tab
  6. LG Optimus T Motherboard Replacement: passo 6, immagine 1 di 2 LG Optimus T Motherboard Replacement: passo 6, immagine 2 di 2
    • Remove SD card mount. Insert the plastic opening tool on the right side to pop off
  7. LG Optimus T Motherboard Replacement: passo 7, immagine 1 di 2 LG Optimus T Motherboard Replacement: passo 7, immagine 2 di 2
    • Remove metal panel
    • There are four retaining points to insert plastic opening tool and pop off panel
  8. LG Optimus T Motherboard Replacement: passo 8, immagine 1 di 1
    • Use a J0 screwdriver to remove the two 1.8mm screws from charging port. (Charging port and motherboard are connected.)
    • Remove motherboard
Conclusione
stacey
Membro da: 02/07/17
219 Reputazione
2 Guide realizzate
Ohio State, Team 1-3, Wilder Spring 2017 Membro di Ohio State, Team 1-3, Wilder Spring 2017
OSU-WILDER-S17S1G3
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 308
