Salta al contenuto principale
LG Optimus T Camera and Camera Mount Replacement
Cosa ti serve
  1. LG Optimus T Camera and Camera Mount Replacement, Camera: passo 1, immagine 1 di 2 LG Optimus T Camera and Camera Mount Replacement, Camera: passo 1, immagine 2 di 2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down your device before you begin.
    • Use a plastic opening tool to remove the phone's back cover. At the top of the phone there are indentations to insert the spudger and pop the case off
  2. LG Optimus T Camera and Camera Mount Replacement: passo 2, immagine 1 di 1
    • Remove the battery by pulling up on the battery using the indentation to the left of the camera lens
  3. LG Optimus T Camera and Camera Mount Replacement: passo 3, immagine 1 di 1
    • Use a J0 screwdriver to remove the 6 highlighted screws
  4. LG Optimus T Camera and Camera Mount Replacement: passo 4, immagine 1 di 2 LG Optimus T Camera and Camera Mount Replacement: passo 4, immagine 2 di 2
    • Remove interior case using indentations on the top and bottom to insert the spudger to pop off the interior case
    • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic one fails
  5. LG Optimus T Camera and Camera Mount Replacement: passo 5, immagine 1 di 1
    • Unhook the connector tab
  6. LG Optimus T Camera and Camera Mount Replacement: passo 6, immagine 1 di 1
    • Remove SD card mount by inserting the plastic opening tool on the right side of the device to pop mount off
  7. LG Optimus T Camera and Camera Mount Replacement: passo 7, immagine 1 di 2 LG Optimus T Camera and Camera Mount Replacement: passo 7, immagine 2 di 2
    • Remove metal panel by inserting plastic opening tool into the four retaining points and remove panel
  8. LG Optimus T Camera and Camera Mount Replacement: passo 8, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • disconnect camera connector from motherboard by spudger
    • Once disconnected, remove camera using tweezers
Conclusione
stacey
Membro da: 02/07/17
219 Reputazione
2 Guide realizzate
Ohio State, Team 1-3, Wilder Spring 2017 Membro di Ohio State, Team 1-3, Wilder Spring 2017
OSU-WILDER-S17S1G3
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 127
