Salta al contenuto principale
LG Optimus L9 P769 Rear Facing Camera Replacement
Cosa ti serve
  1. LG Optimus L9 P769 Rear Facing Camera Replacement, Removing the Back Panel: passo 1, immagine 1 di 2 LG Optimus L9 P769 Rear Facing Camera Replacement, Removing the Back Panel: passo 1, immagine 2 di 2
    • Pry the back panel from the frame of the phone to reveal the motherboard.
  2. LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard: passo 2, immagine 1 di 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard: passo 2, immagine 2 di 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard: passo 2, immagine 3 di 3
    • Detach the connectors on the motherboard.
  3. LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard Cont.: passo 3, immagine 1 di 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard Cont.: passo 3, immagine 2 di 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard Cont.: passo 3, immagine 3 di 3
    • Continue to lift the connectors off the motherboard.
  4. LG Optimus L9 P769 Rear Facing Camera Replacement, Lifting Motherboard from the Phone: passo 4, immagine 1 di 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Lifting Motherboard from the Phone: passo 4, immagine 2 di 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Lifting Motherboard from the Phone: passo 4, immagine 3 di 3
    • Lift the speaker cable off the motherboard.
    • Lift the motherboard up. It will Still be connected to the frame.
  5. LG Optimus L9 P769 Rear Facing Camera Replacement, Pry and remove the camera: passo 5, immagine 1 di 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Pry and remove the camera: passo 5, immagine 2 di 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Pry and remove the camera: passo 5, immagine 3 di 3
    • Pry under the camera to lift it off the frame.
    • There is some adhesive that will keep it attached to the frame, pulling the camera off will not damage the phone.
    • The camera should now be entirely separated from the phone.
Conclusione
Paul
Membro da: 10/07/14
145 Reputazione
4 Guide realizzate
USF Tampa, Team 8-1, Leahy Fall 2014 Membro di USF Tampa, Team 8-1, Leahy Fall 2014
USFT-LEAHY-F14S8G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 972
