Introduzione
The following guide explains how to replace the speaker.
Remove back cover.
  • Remove back cover.
  • Remove the battery and simcard.
Aggiungi Commento
Remove the 12 screws (with the phillips head 000) around frame and near sim and sd cards.
  • Remove the 12 screws (with the phillips head 000) around frame and near sim and sd cards.
Aggiungi Commento
  • Remove bottom plate where the charger port is located.
Aggiungi Commento
  • Remove the back piece.
Aggiungi Commento
  • Locate the speaker on reverse side of back piece.
  • Using a Spudger, lift off the speaker and replace as needed.
Aggiungi Commento
Conclusione
Bruna
Membro da: 08/10/2014
519 Reputazione
4 Guide realizzate
USF Tampa, Team 9-1, Leahy Fall 2014 Membro di USF Tampa, Team 9-1, Leahy Fall 2014
USFT-LEAHY-F14S9G1
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 775
