Salta al contenuto principale
LG Optimus L7 P705 SIM Card Slot Replacement
Cosa ti serve
  1. LG Optimus L7 P705 SIM Card Slot Replacement, Home Button: passo 1, immagine 1 di 2 LG Optimus L7 P705 SIM Card Slot Replacement, Home Button: passo 1, immagine 2 di 2
    • Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
    • Remove the battery and SIM card.
  2. LG Optimus L7 P705 SIM Card Slot Replacement: passo 2, immagine 1 di 1
    • Remove the twelve screws using the Phillips 000 screwdriver.
  3. LG Optimus L7 P705 SIM Card Slot Replacement: passo 3, immagine 1 di 1
    • Remove bottom plate where the charger port is located.
  4. LG Optimus L7 P705 SIM Card Slot Replacement: passo 4, immagine 1 di 2 LG Optimus L7 P705 SIM Card Slot Replacement: passo 4, immagine 2 di 2
    • Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
  5. LG Optimus L7 P705 SIM Card Slot Replacement: passo 5, immagine 1 di 1
    • Flip over to the face of the device.
    • Lift off the glass screen (display).
  6. LG Optimus L7 P705 SIM Card Slot Replacement: passo 6, immagine 1 di 1
    • Remove the home screen button. Replace as needed.
  7. LG Optimus L7 P705 SIM Card Slot Replacement, SIM Card Slot: passo 7, immagine 1 di 2 LG Optimus L7 P705 SIM Card Slot Replacement, SIM Card Slot: passo 7, immagine 2 di 2
    • Flip over to the back of the device
    • Using the plastic spudger, lift off the three board-to-board connectors on the left-hand side of the device.
  8. LG Optimus L7 P705 SIM Card Slot Replacement: passo 8, immagine 1 di 1
    • Using a plastic spudger, lift off the wire connector at the right bottom of the board.
  9. LG Optimus L7 P705 SIM Card Slot Replacement: passo 9, immagine 1 di 2 LG Optimus L7 P705 SIM Card Slot Replacement: passo 9, immagine 2 di 2
    • Detach the mount including both the SIM card and the motherboard from the device.
Conclusione
Yanxiang Ding
Membro da: 01/25/17
101 Reputazione
1 Guida realizzata
IUPUI, Team 2-2, Baechle Spring 2017 Membro di IUPUI, Team 2-2, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G2
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 627
