Salta al contenuto principale
Introduzione
The following guide explains how to replace the headphone jack.
Parti
Nessuna parte specificata.
  1. Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone. Remove the battery and simcard.
    • Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
    • Remove the battery and simcard.
  2. Remove twelve 3mm screws (with the phillips head 000) around frame and near sim and sd cards.
    • Remove twelve 3mm screws (with the phillips head 000) around frame and near sim and sd cards.
  3. Remove bottom plate where the charger port is located.
    • Remove bottom plate where the charger port is located.
  4. Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover. Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
    • Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
  5. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  6. Flip over to the face of the device. Lift off glass screen (display).
    • Flip over to the face of the device.
    • Lift off glass screen (display).
  7. Flip over to the back of the device Using the plastic spudger, lift off the three board-to-board connectors on the left-hand side of the device.
    • Flip over to the back of the device
    • Using the plastic spudger, lift off the three board-to-board connectors on the left-hand side of the device.
  8. Using a plastic spudger, lift off the wire connector at the right bottom of the board.
    • Using a plastic spudger, lift off the wire connector at the right bottom of the board.
  9. Detach the mount including both the SIM card and the motherboard from the device. Detach the mount including both the SIM card and the motherboard from the device.
    • Detach the mount including both the SIM card and the motherboard from the device.
  10. Lift off the connector using the plastic spudger.
    • Lift off the connector using the plastic spudger.
  11. Lift the speaker connector using the plastic spudger.
    • Lift the speaker connector using the plastic spudger.
  12. Flip over to the back of the device. Lift off the connector on the left using the plastic spudger. Lift off the headphone jack connector on the top right using the plastic spudger. Replace the board containing the headphone jack.
    • Flip over to the back of the device. Lift off the connector on the left using the plastic spudger.
    • Lift off the headphone jack connector on the top right using the plastic spudger.
    • Replace the board containing the headphone jack.
Conclusione
Tianyu Song
Membro da: 24/01/2017
107 Reputazione
1 Guida realizzata
IUPUI, Team 2-2, Baechle Spring 2017 Membro di IUPUI, Team 2-2, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G2
4 Membri
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 259
