Salta al contenuto principale
LG Optimus G Pro Battery Replacement
Cosa ti serve
  1. LG Optimus G Pro Battery Replacement, Remove Back Cover.: passo 1, immagine 1 di 1
    • Make sure before you begin working on your device, that the device is not charging.
    • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
  2. LG Optimus G Pro Battery Replacement, Remove the Battery.: passo 2, immagine 1 di 1
    • Once you have properly removed the outer casing, the back should look as so.
    • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
    • Once the battery is removed you may safely proceed to the next step.
Conclusione
Altre 10 persone hanno completato questa guida.
Wesley Pate
Membro da: 09/25/14
1.641 Reputazione
7 Guide realizzate
USF Tampa, Team 15-5, Remmell Fall 2014 Membro di USF Tampa, Team 15-5, Remmell Fall 2014
USFT-REMMELL-F14S15G5
3 Membri
7 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 21
Tutti i Tempi: 3,238
