Introduzione
This guide will lead you through removing the initial covering and the battery on the LG Optimus G Pro.
Cosa ti serve
Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
Once you have properly removed the outer casing, the back should look as so.
To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
Once the battery is removed you may safely proceed to the next step.
Altre 10 persone hanno completato questa guida.
