Salta al contenuto principale
LG Optimus Fuel Speaker Replacement
Cosa ti serve
  1. LG Optimus Fuel Speaker Replacement, Battery: passo 1, immagine 1 di 2 LG Optimus Fuel Speaker Replacement, Battery: passo 1, immagine 2 di 2
    • Use the opening on the right side of the phone to pull off the plastic back cover.
  2. LG Optimus Fuel Speaker Replacement: passo 2, immagine 1 di 3 LG Optimus Fuel Speaker Replacement: passo 2, immagine 2 di 3 LG Optimus Fuel Speaker Replacement: passo 2, immagine 3 di 3
    • Use the curved opening at the center-bottom of the battery to carefully remove the old battery.
  3. LG Optimus Fuel Speaker Replacement, Speaker: passo 3, immagine 1 di 3 LG Optimus Fuel Speaker Replacement, Speaker: passo 3, immagine 2 di 3 LG Optimus Fuel Speaker Replacement, Speaker: passo 3, immagine 3 di 3
    • Remove the six 1.4mm screws using a Phillips head screwdriver with a size PH00 bit. Then fully remove the back panel with a plastic opening tool.
  4. LG Optimus Fuel Speaker Replacement: passo 4, immagine 1 di 3 LG Optimus Fuel Speaker Replacement: passo 4, immagine 2 di 3 LG Optimus Fuel Speaker Replacement: passo 4, immagine 3 di 3
    • Remove the speaker from the back panel. You may have to use some tweezers if you are having a hard time grabbing the speaker with your fingers.
    • Remember to take note of where the two springs on the speaker are positioned before removing it. Install the new speaker with the springs in this same position.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 7
Tutti i Tempi: 244
