Introduzione
Replace digitizer glass in LG Optimus F3 LS720. Also demonstrates almost complete teardown.
Cosa ti serve
Remove Back Cover
Remove SDCard (if you have one)
Remove SIM Card
Remove Battery
Altre 4 persone hanno completato questa guida.
3 Commenti
I followed the guide, put it back together but it now starts up and only stays up for a bit before reporting a heating issue. It feels hot in the upper left hand corner of the phone as well as the back upper middle.
any thoughts on what I did wrong?
I did this repair successfully, and linked to an album of photos below. I actually took these photos while putting it back together, but I reversed the order to help with taking it apart.
There's a couple things to watch out for.
First - there's two versions of the screen for the LG Optimus F3. You either have the (LS720/MS659/VM720) screen, which has rounded corners at the top (like mine), or the (MS659/P659), which has square corners at the top. I bought the wrong one, and cracked it trying to grind the corners off at the top.
You will need to use a heat gun to get the old screen off, and I just used an epoxy to attach the new one.
When reassembling, make sure all of your wires are plugged back in. I missed one, and I was getting no signal. Last thing - make sure you put the main center button in before you snap the front screen assembly to the main phone body.
