Salta al contenuto principale
Introduzione
For trouble with touch feedback or if your screen is cracked and you want to replace it.
Parti
Nessuna parte specificata.
  1. Make sure not to push the tool into the USB port. Doing so may cause damage to your phone. Hold the blue plastic opening tool at the edge of the USB opening. Push down and pry the case off the phone gently.
    • Make sure not to push the tool into the USB port. Doing so may cause damage to your phone.
    • Hold the blue plastic opening tool at the edge of the USB opening. Push down and pry the case off the phone gently.
  2. Lift the battery out of the phone and replace with your new one.
    • Lift the battery out of the phone and replace with your new one.
    Where can I purchase a new battery for this life's good optimist dynamic II TracFone. Or something compatible
    Carolyn Lane - Replica
  3. Grab the end of the SD Card and pull it out of the phone.
    • Grab the end of the SD Card and pull it out of the phone.
  4. Use the PH #000 screwdriver to remove the six screws from the midframe Use the PH #000 screwdriver to remove the six screws from the midframe
    • Use the PH #000 screwdriver to remove the six screws from the midframe
  5. Using the plastic opening tool, work gently to go around the perimeter of the phone and remove the midframe. Using the plastic opening tool, work gently to go around the perimeter of the phone and remove the midframe.
    • Using the plastic opening tool, work gently to go around the perimeter of the phone and remove the midframe.
  6. Use the plastic opening tool to disconnect the small orange tab from the motherboard. Next disconnect the silver tab slightly above where the orange tab was. Next disconnect the silver tab slightly above where the orange tab was.
    • Use the plastic opening tool to disconnect the small orange tab from the motherboard.
    • Next disconnect the silver tab slightly above where the orange tab was.
  7. Gently feed the orange and silver tabbed ribbons through the hole in the motherboard and the screen will be free.
    • Gently feed the orange and silver tabbed ribbons through the hole in the motherboard and the screen will be free.
Conclusione
Altre 6 persone hanno completato questa guida.
Patrick Barron
Membro da: 08/10/2014
158 Reputazione
1 Guida realizzata
USF Tampa, Team 14-3, Leahy Fall 2014 Membro di USF Tampa, Team 14-3, Leahy Fall 2014
USFT-LEAHY-F14S14G3
4 Membri
3 Guide realizzate
My screen is black but everything else works (even the touch screen -- I can use it to answer calls). I used this guide to change the screens from a working phone - but my screen is still black! Anyone have any ideas?
Jack - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,055
