Introduzione
Make sure your phone is turned off before beginning any dissection of your device.
Cosa ti serve
Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
The battery is the large black rectangle towards the bottom half of the phone.
There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
Remove 9 screws from the phone. The locations of these screws are circled in the picture.
5.5mm length PH00 screws
4mm length PH00 screws
Using a plastic opening tool, gently pry around the perimeter of the device.
The button covers rest under the Mid-Cover Bezel. Remove them and set aside.
Using a spudger or plastic opening tool, gently disconnect the ribbon cable attached to the black SIM card board.
Use a hair-dryer on high, or a heat-gun on low to heat the device and loosen the adhesive which holds down the SD/SIM Card Board.
Evenly heat the device in short intervals for about one minute.
Gently pry the board up to release it from the now soft adhesive. Make sure you pry up the little tab connected to the camera unit as well.
If the board is too difficult to separate than more heating may be required.
Heat the camera assembly in 20-30 seconds intervals with a heat gun set on low, or a hair drying set on high.
Using tweezers or a pry tool, gently wiggle and lift the camera assembly away from the body of the phone.
