Salta al contenuto principale
LG Optimus 3D MicroSD/SIM Card Board Replacement
Cosa ti serve
  1. LG Optimus 3D MicroSD/SIM Card Board Replacement, Back Cover Removal: passo 1, immagine 1 di 2 LG Optimus 3D MicroSD/SIM Card Board Replacement, Back Cover Removal: passo 1, immagine 2 di 2
    • Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
  2. LG Optimus 3D MicroSD/SIM Card Board Replacement, Battery Removal: passo 2, immagine 1 di 3 LG Optimus 3D MicroSD/SIM Card Board Replacement, Battery Removal: passo 2, immagine 2 di 3 LG Optimus 3D MicroSD/SIM Card Board Replacement, Battery Removal: passo 2, immagine 3 di 3
    • The battery is the large black rectangle towards the bottom half of the phone.
    • There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
  3. LG Optimus 3D MicroSD/SIM Card Board Replacement, Screw Removal: passo 3, immagine 1 di 2 LG Optimus 3D MicroSD/SIM Card Board Replacement, Screw Removal: passo 3, immagine 2 di 2
    • Remove 9 screws from the phone. The locations of these screws are circled in the picture.
    • 5.5mm length PH00 screws
    • 4mm length PH00 screws
  4. LG Optimus 3D MicroSD/SIM Card Board Replacement, Bottom Cover Removal: passo 4, immagine 1 di 2 LG Optimus 3D MicroSD/SIM Card Board Replacement, Bottom Cover Removal: passo 4, immagine 2 di 2
    • Gently pull down on the bottom cover to remove it.
  5. LG Optimus 3D MicroSD/SIM Card Board Replacement, Mid-Cover Bezel Removal: passo 5, immagine 1 di 3 LG Optimus 3D MicroSD/SIM Card Board Replacement, Mid-Cover Bezel Removal: passo 5, immagine 2 di 3 LG Optimus 3D MicroSD/SIM Card Board Replacement, Mid-Cover Bezel Removal: passo 5, immagine 3 di 3
    • Using a plastic opening tool, gently pry around the perimeter of the device.
    • The ribbons behind the buttons and ports are very delicate. Make sure you do not run your plastic opening tool too deep into the bezel, as you could damage them.
    • The button covers rest under the Mid-Cover Bezel. Remove them and set aside.
  6. LG Optimus 3D MicroSD/SIM Card Board Replacement, Ribbon Cable Disconnection: passo 6, immagine 1 di 2 LG Optimus 3D MicroSD/SIM Card Board Replacement, Ribbon Cable Disconnection: passo 6, immagine 2 di 2
    • Using a spudger or plastic opening tool, gently disconnect the ribbon cable attached to the black SIM card board.
  7. LG Optimus 3D MicroSD/SIM Card Board Replacement, Adhesive Loosening: passo 7, immagine 1 di 1
    • Use a hair-dryer on high, or a heat-gun on low to heat the device and loosen the adhesive which holds down the SD/SIM Card Board.
    • Evenly heat the device in short intervals for about one minute.
    • Do not heat the device for more than 30 seconds at a time to prevent over-heating.
  8. LG Optimus 3D MicroSD/SIM Card Board Replacement, SD/SIM Card Board Removal: passo 8, immagine 1 di 3 LG Optimus 3D MicroSD/SIM Card Board Replacement, SD/SIM Card Board Removal: passo 8, immagine 2 di 3 LG Optimus 3D MicroSD/SIM Card Board Replacement, SD/SIM Card Board Removal: passo 8, immagine 3 di 3
    • Gently pry the board up to release it from the now soft adhesive. Make sure you pry up the little tab connected to the camera unit as well.
    • If the board is too difficult to separate than more heating may be required.
Conclusione
USF Tampa, Team 10-6, Brown Fall 2014 Membro di USF Tampa, Team 10-6, Brown Fall 2014
USFT-BROWN-F14S10G6
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 11
Tutti i Tempi: 946
