Introduzione
The SD/SIM card board houses the SD and SIM cards, and connects them to main circuitry of the phone.
Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
  • Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
Aggiungi Commento
The battery is the large black rectangle towards the bottom half of the phone.
  • The battery is the large black rectangle towards the bottom half of the phone.
  • There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
Aggiungi Commento
  • Remove 9 screws from the phone. The locations of these screws are circled in the picture.
  • 5.5mm length PH00 screws
  • 4mm length PH00 screws
Aggiungi Commento
  • Gently pull down on the bottom cover to remove it.
Aggiungi Commento
  • Using a plastic opening tool, gently pry around the perimeter of the device.
  • The ribbons behind the buttons and ports are very delicate. Make sure you do not run your plastic opening tool too deep into the bezel, as you could damage them.
  • The button covers rest under the Mid-Cover Bezel. Remove them and set aside.
I think they want you to refer to the blue tool as the "plastic opening tool."
Dan Brown - Replica
  • Using a spudger or plastic opening tool, gently disconnect the ribbon cable attached to the black SIM card board.
Aggiungi Commento
  • Use a hair-dryer on high, or a heat-gun on low to heat the device and loosen the adhesive which holds down the SD/SIM Card Board.
  • Evenly heat the device in short intervals for about one minute.
  • Do not heat the device for more than 30 seconds at a time to prevent over-heating.
You could also use the iOpener tool for this step. What is that the adhesive is holding in place?
Dan Brown - Replica
  • Gently pry the board up to release it from the now soft adhesive. Make sure you pry up the little tab connected to the camera unit as well.
  • If the board is too difficult to separate than more heating may be required.
Aggiungi Commento
Conclusione
Dale Pearson
Membro da: 22/09/2014
775 Reputazione
6 Guide realizzate
USF Tampa, Team 10-6, Brown Fall 2014 Membro di USF Tampa, Team 10-6, Brown Fall 2014
USFT-BROWN-F14S10G6
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 740
