Introduzione
If your LG Neon II won't slide the way it should be the springs probably need to be replaced. This guide will show you how.
Cosa ti serve
To gain access to the phone’s speaker, grip the phone firmly in an inverted position with the back of the unit facing up and the LG insignia positioned away from you.
Using both hands as support, use your thumbs to gently guide the rear housing away and in the direction of the arrow.
To separate the button board/circuit module from the phone main frame, firmly, but gently, unscrew (counter-clockwise) the seven outside 4 mm screws along the rear outside rim of the main body.
Using the plastic opening tool, gently pry the circuit board from the phone.
The partially separated circuit board may be attached to the main button area by factory adhesive/tape. If so, use a soft padded surface to rest the mother board on. Your work area will still be accessible without separating the two units.
After prying the circuit board up, it will be attached by black tape. This tape connects the circuit board to a metal rectangle.
Use the spudger between this metal rectangle and the phone to disconnect the two halves of the phone.
