Salta al contenuto principale
LG Neon GT 365 Keyboard Replacement
Cosa ti serve
  1. LG Neon GT 365 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 LG Neon GT 365 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • With one hand, push the rectangular button located on the back top-side of the phone.
    • With your other hand, remove the rear cover.
  2. LG Neon GT 365 Keyboard Replacement: passo 2, immagine 1 di 1
    • Remove 5 screws, 1 from each corner of the phone and 1 from the center-right of the phone.
  3. LG Neon GT 365 Keyboard Replacement: passo 3, immagine 1 di 2 LG Neon GT 365 Keyboard Replacement: passo 3, immagine 2 di 2
    • Now pull off the rear casing, using an opening tool. **Buttons for volume and pictures may fall out**
  4. LG Neon GT 365 Keyboard Replacement: passo 4, immagine 1 di 1
    • Hold the circuit board and turn the phone upside down.
    • Then let the circuit board hang down so you can disconnect the ribbon by getting under an edge and popping it off. **the rubber keyboard may fall out**
  5. LG Neon GT 365 Keyboard Replacement: passo 5, immagine 1 di 1
    • Once the circuit board has been removed the rubber keypad will be visible. If it has not fallen out on its own it can simply be peeled out. It is lightly attached like a sticker on the top three tabs. The left most table is labeled “B”, the center tab is blank, and the right tab is labeled “N”.
Conclusione
kristie
Membro da: 10/23/13
538 Reputazione
5 Guide realizzate
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013 Membro di UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S2G1
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 288
