Salta al contenuto principale
LG Muziq LX570 Keypad Replacement
Cosa ti serve
  1. LG Muziq LX570 Keypad Replacement, Battery: passo 1, immagine 1 di 2 LG Muziq LX570 Keypad Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the battery cover release towards top of phone.
    • Place one finger at each side of the battery cover.
    • Lift and remove the battery cover.
  2. LG Muziq LX570 Keypad Replacement: passo 2, immagine 1 di 2 LG Muziq LX570 Keypad Replacement: passo 2, immagine 2 di 2
    • Place a finger at the top corner of the battery and lift out of the phone.
  3. LG Muziq LX570 Keypad Replacement, Rear Case: passo 3, immagine 1 di 2 LG Muziq LX570 Keypad Replacement, Rear Case: passo 3, immagine 2 di 2
    • Use the spudger to lift up the two screw covers at the top of the phone.
    • Remove all four Phillips#00 (3.3mm) screws with screwdriver.
  4. LG Muziq LX570 Keypad Replacement: passo 4, immagine 1 di 3 LG Muziq LX570 Keypad Replacement: passo 4, immagine 2 di 3 LG Muziq LX570 Keypad Replacement: passo 4, immagine 3 di 3
    • Use the spudger to lift up the rear case from the phone.
    • Note: Rear case is connected on all sides and will have to be detached on all sides before removal.
    • Remove the rear case from the device.
  5. LG Muziq LX570 Keypad Replacement, Motherboard: passo 5, immagine 1 di 3 LG Muziq LX570 Keypad Replacement, Motherboard: passo 5, immagine 2 di 3 LG Muziq LX570 Keypad Replacement, Motherboard: passo 5, immagine 3 di 3
    • Use the spudger to lift the motherboard from the phone.
  6. LG Muziq LX570 Keypad Replacement, Keypad: passo 6, immagine 1 di 3 LG Muziq LX570 Keypad Replacement, Keypad: passo 6, immagine 2 di 3 LG Muziq LX570 Keypad Replacement, Keypad: passo 6, immagine 3 di 3
    • Caution: The circuit board is connected via ribbon to the phone. Do not break this connection.
    • Note: The circuit board is attached by clips on both sides of the board. Detach each clip before removing the motherboard from the phone.
    • Use the spudger to detach the circuit board from the phone.
  7. LG Muziq LX570 Keypad Replacement: passo 7, immagine 1 di 3 LG Muziq LX570 Keypad Replacement: passo 7, immagine 2 di 3 LG Muziq LX570 Keypad Replacement: passo 7, immagine 3 di 3
    • Open the phone to expose the keypad.
    • Use your finger to push the keypad from the front towards the circuit board.
    • Remove the keypad from the phone.
Conclusione
Braden Burk
Membro da: 01/22/12
1 Reputazione
5 Guide realizzate
Cal Poly, Team 3-29, Amido Winter 2012 Membro di Cal Poly, Team 3-29, Amido Winter 2012
CPSU-AMIDO-W12S3G29
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 706
