Salta al contenuto principale
LG Muziq LX570 Front Case Replacement
Cosa ti serve
  1. LG Muziq LX570 Front Case Replacement, Front Case: passo 1, immagine 1 di 2 LG Muziq LX570 Front Case Replacement, Front Case: passo 1, immagine 2 di 2
    • Use a spudger to remove the two screw covers below display.
    • Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
  2. LG Muziq LX570 Front Case Replacement: passo 2, immagine 1 di 3 LG Muziq LX570 Front Case Replacement: passo 2, immagine 2 di 3 LG Muziq LX570 Front Case Replacement: passo 2, immagine 3 di 3
    • Caution: Wires and ribbon connect the front case to the main body. Exhibit care when separating front case from the main body as to not break the connections.
    • Note: Side buttons may fall out when removing the front case. Do not misplace them.
    • Note: Each side button will only fit in the side that it came from.
    • Insert a spudger between the black and grey casings and gently spread them apart.
    • Work around the device gradually, opening the gap further.
  3. LG Muziq LX570 Front Case Replacement: passo 3, immagine 1 di 3 LG Muziq LX570 Front Case Replacement: passo 3, immagine 2 di 3 LG Muziq LX570 Front Case Replacement: passo 3, immagine 3 di 3
    • Caution: The wires and ribbon connector can break easily. Exhibit care when removing them.
    • Use the spudger and lift upward to disconnect the ribbon from the main part of the phone.
    • Carefully remove any parts stuck to the front case such as speakers.
Conclusione
Raymond Ching
Membro da: 01/19/12
1 Reputazione
1 Guida realizzata
Cal Poly, Team 3-29, Amido Winter 2012 Membro di Cal Poly, Team 3-29, Amido Winter 2012
CPSU-AMIDO-W12S3G29
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 11
Tutti i Tempi: 581
