Parti
Nessuna parte richiesta.
Use a spudger to remove the two screw covers below display.
  • Use a spudger to remove the two screw covers below display.
  • Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
Aggiungi Commento
Caution: Wires and ribbon connect the front case to the main body. Exhibit care when separating front case from the main body as to not break the connections.
  • Caution: Wires and ribbon connect the front case to the main body. Exhibit care when separating front case from the main body as to not break the connections.
  • Note: Side buttons may fall out when removing the front case. Do not misplace them.
  • Note: Each side button will only fit in the side that it came from.
  • Insert a spudger between the black and grey casings and gently spread them apart.
  • Work around the device gradually, opening the gap further.
Aggiungi Commento
  • Caution: The wires and ribbon connector can break easily. Exhibit care when removing them.
  • Use the spudger and lift upward to disconnect the ribbon from the main part of the phone.
  • Carefully remove any parts stuck to the front case such as speakers.
Aggiungi Commento
Conclusione
Raymond Ching
Membro da: 19/01/2012
1 Reputazione
1 Guida realizzata
Cal Poly, Team 3-29, Amido Winter 2012 Membro di Cal Poly, Team 3-29, Amido Winter 2012
CPSU-AMIDO-W12S3G29
4 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 515
