Salta al contenuto principale
LG Leon LTE Motherboard Replacement
Cosa ti serve
  1. LG Leon LTE Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 LG Leon LTE Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Turn the phone over so the back is facing upward.
  2. LG Leon LTE Motherboard Replacement: passo 2, immagine 1 di 3 LG Leon LTE Motherboard Replacement: passo 2, immagine 2 di 3 LG Leon LTE Motherboard Replacement: passo 2, immagine 3 di 3
    • Insert your opening tool in the incision at the bottom center of the phone.
    • Push upward with the opening tool to pry the back of the phone open.
    • Remove the back completely and set aside.
  3. LG Leon LTE Motherboard Replacement: passo 3, immagine 1 di 3 LG Leon LTE Motherboard Replacement: passo 3, immagine 2 di 3 LG Leon LTE Motherboard Replacement: passo 3, immagine 3 di 3
    • Using the Phillips #0 screwdriver, unscrew the 8 screws that secure the back frame to the body of the phone.
    • Remember to put the screws in a safe place so you don't lose them.
    • Once all screws are removed, use the opening tool to pry the back frame of the phone free.
  4. LG Leon LTE Motherboard Replacement: passo 4, immagine 1 di 2 LG Leon LTE Motherboard Replacement: passo 4, immagine 2 di 2
    • Using the opening tool, gently pry the phone's earpiece off. Set aside.
    • Separate the old motherboard from the phone fixture by pulling it apart.
    • Gently press the replacement motherboard into the phone fixture.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 687
