Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Use this guide to remove the speakers from the device.
Parti
Nessuna parte specificata.
  1. Use the spudger to pry out the indicated rubber squares. Use the #0 Phillips screwdriver to take out the revealed screws. Use the #0 Phillips screwdriver to take out the revealed screws.
    • Use the spudger to pry out the indicated rubber squares.
    • Use the #0 Phillips screwdriver to take out the revealed screws.
  2. Carefully lodge the spudger between the face plate and the hinge mechanism. Gently pry the face plate until it releases from place holders. Gently pry the face plate until it releases from place holders.
    • Carefully lodge the spudger between the face plate and the hinge mechanism.
    • Gently pry the face plate until it releases from place holders.
  3. Using a spudger, detach the speakers from their place holders. Using a spudger, detach the speakers from their place holders.
    • Using a spudger, detach the speakers from their place holders.
  4. Using the spudger, pry between the speaker circuit board and base to detach with ease.
    • Using the spudger, pry between the speaker circuit board and base to detach with ease.
Conclusione
Altre 2 persone hanno completato questa guida.
Harry Black
Membro da: 20/04/2010
56 Reputazione
1 Guida realizzata
Cal Poly, Team 10-44, Garner Spring 2010 Membro di Cal Poly, Team 10-44, Garner Spring 2010
CPSU-GARNER-S10S10G44
4 Membri
18 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,456
