Salta al contenuto principale
LG LX150 Battery Replacement
  1. LG LX150 Battery Replacement, Back Cover: passo 1, immagine 1 di 3 LG LX150 Battery Replacement, Back Cover: passo 1, immagine 2 di 3 LG LX150 Battery Replacement, Back Cover: passo 1, immagine 3 di 3
    • First locate the button and the bottom of the cover where the arrow is. Press down on the button.
    • While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
    • The battery will be visible after removing the back cover.
  2. LG LX150 Battery Replacement, Battery: passo 2, immagine 1 di 2 LG LX150 Battery Replacement, Battery: passo 2, immagine 2 di 2
    • Simultaneously push the battery forward and pull up from the bottom.
  3. LG LX150 Battery Replacement: passo 3, immagine 1 di 1
    • Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
    • Be careful of damaged or leaking batteries. If your battery appears damaged, remove it with care and find a replacement.
Conclusione
Andrea
Membro da: 04/19/10
110 Reputazione
4 Guide realizzate
Cal Poly, Team 10-44, Garner Spring 2010 Membro di Cal Poly, Team 10-44, Garner Spring 2010
CPSU-GARNER-S10S10G44
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,435
