Salta al contenuto principale
LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement
Cosa ti serve
  1. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement, Filter: passo 1, immagine 1 di 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement, Filter: passo 1, immagine 2 di 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement, Filter: passo 1, immagine 3 di 3
    • Find a replacement water filter based on the model number for your fridge.
    • You can also bring your old water filter to a store to get a suitable replacement that way.
  2. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: passo 2, immagine 1 di 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: passo 2, immagine 2 di 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: passo 2, immagine 3 di 3
    • For the best result, it's best to buy the original filter that was made for the fridge as opposed to an aftermarket water filter.
    • Remove the water filter from the box .
    • Remove the cap from the water filter.
  3. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: passo 3, immagine 1 di 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: passo 3, immagine 2 di 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: passo 3, immagine 3 di 3
    • Open the water filter bay in the top left corner of the fridge.
    • Remove the existing water filter inside. Or, if your fridge doesn't yet have a water filter, remove the green cap instead.
  4. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: passo 4, immagine 1 di 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: passo 4, immagine 2 di 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: passo 4, immagine 3 di 3
    • Angle the receiver in the fridge downward so that the filter is easy to plug in.
    • Firmly press the water filter into the receiver until it is snug and attached.
    • If the water filter falls out once you let go, you simply need to press harder into the receiver.
  5. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: passo 5, immagine 1 di 2 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: passo 5, immagine 2 di 2
    • Shut the water filter cover.
  6. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: passo 6, immagine 1 di 1
    • Purge the system by dispensing water for about 2-3 minutes, or until you have cycled through approximately 64 ounces.
    • Your water should now be clean and crystal clear!
Linea Traguardo
Luc Charles
Membro da: 03/22/21
154 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 106
Tutti i Tempi: 6,644
