Salta al contenuto principale
LG L1200 Outer LCD Screen Replacement
Cosa ti serve
  1. LG L1200 Outer LCD Screen Replacement, Inner LCD Screen: passo 1, immagine 1 di 1
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Flip open the phone and locate the four screw covers.
  2. LG L1200 Outer LCD Screen Replacement: passo 2, immagine 1 di 1
    • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
  3. LG L1200 Outer LCD Screen Replacement: passo 3, immagine 1 di 1
    • Using a T6 Torx screwdriver, remove all four screws.
  4. LG L1200 Outer LCD Screen Replacement: passo 4, immagine 1 di 3 LG L1200 Outer LCD Screen Replacement: passo 4, immagine 2 di 3 LG L1200 Outer LCD Screen Replacement: passo 4, immagine 3 di 3
    • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
    • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
  5. LG L1200 Outer LCD Screen Replacement: passo 5, immagine 1 di 2 LG L1200 Outer LCD Screen Replacement: passo 5, immagine 2 di 2
    • Pull the inner screen cover towards you and up in order to separate it from the front cover.
  6. LG L1200 Outer LCD Screen Replacement: passo 6, immagine 1 di 1
    • Remove the tape from the bottom of the LCD screen.
  7. LG L1200 Outer LCD Screen Replacement: passo 7, immagine 1 di 3 LG L1200 Outer LCD Screen Replacement: passo 7, immagine 2 di 3 LG L1200 Outer LCD Screen Replacement: passo 7, immagine 3 di 3
    • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
  8. LG L1200 Outer LCD Screen Replacement: passo 8, immagine 1 di 3 LG L1200 Outer LCD Screen Replacement: passo 8, immagine 2 di 3 LG L1200 Outer LCD Screen Replacement: passo 8, immagine 3 di 3
    • Flip the screen over so that you can see the outer LCD screen and the circuit board.
    • Insert spudger in the bottom right corner.
    • Lift up and move the spudger across the bottom.
    • The third photo is rotated 180 degrees.
  9. LG L1200 Outer LCD Screen Replacement: passo 9, immagine 1 di 2 LG L1200 Outer LCD Screen Replacement: passo 9, immagine 2 di 2
    • Use the pointy side of the spudger to peel off the interior tape.
    • Flip the assembly over and peel the circuit board from the screen.
  10. LG L1200 Outer LCD Screen Replacement: passo 10, immagine 1 di 2 LG L1200 Outer LCD Screen Replacement: passo 10, immagine 2 di 2
    • Use the spudger to remove the LCD screen from its backing.
  11. LG L1200 Outer LCD Screen Replacement, Outer LCD Screen: passo 11, immagine 1 di 1
    • The outer LCD screen can be found on the circuit board, which is attached to the back of the inner LCD screen.
  12. LG L1200 Outer LCD Screen Replacement: passo 12, immagine 1 di 2 LG L1200 Outer LCD Screen Replacement: passo 12, immagine 2 di 2
    • Use an IPod opening tool to carefully lift the screen from its backing.
    • Use your finger to pull the screen forward.
  13. LG L1200 Outer LCD Screen Replacement: passo 13, immagine 1 di 2 LG L1200 Outer LCD Screen Replacement: passo 13, immagine 2 di 2
    • Pull the screen and the tape ribbon off the circuit board.
Conclusione
Cal Poly, Team 6-14, Maness Spring 2010 Membro di Cal Poly, Team 6-14, Maness Spring 2010
CPSU-MANESS-S10S6G14
4 Membri
16 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,000
